Old 06-21-2003, 10:40 PM
slammed87 slammed87 is offline
brushless t3??
how hard would it be to put a novak brushless into a t3?
could the tranny hold it?
how fast would it be?
Old 06-21-2003, 10:45 PM
End Overend End Overend is offline
It should drop right in with out any problem, you might eventually strip out your idler gear but if you keep your slipper set properly it shouldn't be a problem.
Top end will depend on gearing. If you gear it properly you should expect speeds in the upper 30's (most likely 37-38 mph) which is pretty dang fast in a stadium truck especially off road.
Old 06-21-2003, 11:10 PM
FSU427P FSU427P is offline
I have a BL in my T3 and it's no problem. The system plugged right in and it works fine. I beefed up the tranny a little with a Robinson titanium top shaft for the stealth tranny, but that's the only trans modification I've done. Well, I also put new teflon bearings in the tranny as well, but that's all.
Just for measure, I replaced the stock aluminum CVD's with MIP shiny steel units. I'm not sure if the aluminum units would break under brushless conditions, but I put the steel units in anyways.
Othee than those few mods, it's a regular FT T3 all the way, and it hauls butt!
Old 06-22-2003, 01:10 AM
k_sw31 k_sw31 is offline
Redneck in Disguise
The T3 has no problem handling the power. I have been running a lehner 5300 in my T3 for a while, which has more RPM and torque than the novak, and I have not broken a thing in terms of tranny parts.
Old 06-22-2003, 07:28 PM
well i jus got a b3 today would taht be able to handle the power
same as the t3 right?
Old 06-22-2003, 07:45 PM
DualBL DualBL is offline
slammed - yes
Old 06-22-2003, 07:55 PM
NoPepsiForYou NoPepsiForYou is offline
yea, only difference between buggies and trucks is looks and the suspension (basicly)
Old 06-22-2003, 08:08 PM
This is the honest truth. A buddy of mine has a brushless B3 and it whipped on a TC3 with a 9turn motor. This was a strait drag race. The B3 had nothing done to it besides the BL setup. It was on off road tires and everything. The TC3 (okay it was mine!) was setup with foams. We raced 3 times and he beat me 2 out of three, not bad at all! I became a believer in BL setups after that night.
