I RECENTLY BOUGHT THE N. B. SYSTEM FOR MY XXX-T SPORT. ITS CURRENTLY SET ON PROGRAM 1 UNLIMITED RPM. WHEN I GIVE IT FULL THROTTLE FROM THE START ITS FINE. WHEN I ATTEMPT TO START OFF VERY SLOW IT HESITATES. DOES ANYBODY ELSE HAVE THIS PROBLEM. ANY SUGGESTIONS WOULD BE GREAT.
what do you have it geared at?, are all your batt fresh (radio and car)? did you set the controller for the radio your using? i noticed a smaal bit of hesitation/cogging when my battery is almost dead, but thats about it.
Haven't had any problems either. The only one was my motor locked up due to an internal meltdown. Sent it back and they sent me a new one. Do you have the XXX-t Sport RTR, if so make sure your radio end point adjustments are set a 125% for the forward throttle. I have run 6 and 7 cell packs through mine with out any problems. I am running 18t/86t set up and getting 32mph on 6 cells and 35mph on 7 cells...
AS FAR AS GEARING 18/88 MY THROTTLE IS SET AT 125% I JUST SENT MY RADIO BACK TO HORIZON HOBBY BECAUSE MY SPRING IN MY STEERING WHEEL FEEL OUT OR BROKE. ANYBODY HAVE THAT PROBLEM.
