Well, I took the plunge and sold my comm lathe to purchase a Novak Brushless motor.
I put it in an Associated B3 and I have it geared on the low end of Novak's starting point (22/81). With this gearing it's way fast and the fun part is it can be geared higher. After running a 1500 pack through it I'd guess the motor was only reaching temps of around 120 degrees and the ESC was in the 140-150 range. I may end up with a 23 or 24 tooth pinion but right now on the tracks I run on I don't think I'm going to need it.
I'm going to love not cutting comms any longer and being able to run back to back packs with out cooling the motor off for 5-10 minutes.
With the overall cost comparison of the Novak Brushless to a higher end ESC/Motor why deal with brushes and comm's unless you want to race? I'm sold.
umm if you dont cut your comm once in a while your motor will loose loads of performance and eventually it'll stop running all together once the comm gets dirty enough
Not in actual ROAR leagues. If its just a club race, its usually run watcha brung, so they'll either throw you in with the mods or throw you in with an outlaw class (people running 7 cells, brushless setups, etc.).
i cant wait till they make brushless races, will be alot easier! i agree you dont have to worry about your comm if you oil it and get a fiberglass stick and you shouldnt have to trim it down. but it is still a pain to keep on with the maintenance. brushless is for people who like the more driving time and less down time!!! glad to hear you are liking the brushless set up, seems fun.
I don't know that I'd refer to Brushless as the Dark Side , I'd rather refer it to the bright side since I don't have to do motor maintanence any longer, and I get the same motor performance battery after battery . That's what I would call the Bright Side
This morning I took a worn set of Bowtie tires and dremeled them down to slicks and went out for another run, this time with a 24 tooth pinion (24/81 gearing on my B3) just to see what it could do. The motor and ESC actually seemed to run a lot cooler with the taller gearing.
With the slicks and taller gearing, it wouldn't wheelie any longer It just spun it's wheels off of the line for about 3-4 feet and took off like a rocket .
I think I'm either going to settle on a 23 tooth pinion or go up to a 84 tooth spur as per Novaks recomendations.
This thing is fun, I wish the ESC was smaller though since it doesn't fit very well under the buggy body. For a truck it would be just fine though.
I'm not totally sure since I haven't measured it yet. I'd guess I'm getting around 10 minutes doing a lot of high speed passes on the street in front of my house. I won't be able to get to a track until late next week.
I'm using cheap 2400 packs to power it right now.
RadicalRustler,
I go both ways, having a CEN MT2 monster truck. I like both, and really enjoy nitro for bashing. With the lack of maintanence on the brushless I'll spend a bit more time with it though.
Here is a better response to your question about run times.
I took it out for a quick run this morning with a 1500 Duratrax Shark battery. The run consisted of running on my street with lots of starts, stops, high speed passes and jumping off of curbs, etc. Very little stopping.
My gearing was 22 tooth pinionand 81 tooth spur gear.
The peak charge on the battery was 1749 mAh. I got approximately 7 minutes before the batteries dumped a noticible amount and 7.5 minutes before a complete dump. I then discharged the batteries to 2.4 volts (I do this with all my NiCad's) and took 207 mAh out of the battery.
So if my math is correct with the same set up and a 3300 mAh battery I would get approximately 11.5 - 12 minutes of run time. Not too bad for having similar speed to a 10 turn brushed motor.
I haven't tried the Sportsman mode yet so I don't know if it makes any difference in run times or speed, and for the most part don't plan on spending much time there .
I hope this gives you a better idea of brushless run times.
