Dual (sensorless) brushless motors on a single ESC?
I'm thinking of putting two milder (Hacker C40) sensorless brushless motors on a single ESC, in this case a JETI Master Car Sport.
I'm only going to be running 6 cells on this, and the vehicle in question is going to be a mostly stock Clod Buster.
Just wondering if this is going to be a bad idea. The MCS on paper and in measurement seems to be able to handle the extra current draw without any problems... but i don't know how two C40s are going to affect it.
My other truck (a 6WD Clod) has three MCS controllers, but each plugged into a single C50 motor. The C50 does drain quite a bit more power than the C40, but i figured i should ask and see what anyone else has to say about this.
My other worry is that a single battery will not be able to keep enough current fed into the two motors to keep them happy. A single C40 running on a touring car i measured out to give about 14A under very light load.
Thoughts?
Thanks in advance!
