Cool, an MT2 forum
I've owned my MT2 for a little over a month now and I'll give my review here.
-The MT2 is very fast out of the box
-The MT2 handles very well around corners and has much less rollover than my 2.5 T-Maxx did (I sold it a while back).
-The simple lay out of the MT2 is nice and much less complicated than other MT's out there
-The big receiver/battery box is very much appreciated
-Flexible body posts do not break nearly as often as those on a T-Maxx.
-Aluminum shock towers are a nice addition
-Easy .21 conversion
-Addition of a 125cc tank is nothing more than a little dremel work and the purchase of the tank (make sure there is room before doing so though)
Dislikes:
-Radio had a range of about 20-30 feet out of the box, sent in for warranty repair but haven't received it back yet
-Engine appeared to have a slight bend in the crankshaft that lead to two stripped spur gears, sent in for warranty repair haven't received it back yet
-No foam for the tires creates a bouncy ride off of jumps and while climbing obsticals at speed
-Some chassis flex in the middle, the roll cage from New Era Models should cure this problem
-Excessive play at the wheels, 10x15mm bearings on the inside of the hub carriers is supposed to cure this
-No local LHS support, everything must be mail ordered (at least for me)
Changes I've made to the MT2 so far:
-Added a JR XR2i transmitter, receiver and servo's to the MT2 since the orignial radio didn't work for me.
-Changed engines to an OS CV-Rx .15 just as powerful as the NT-16 but rev's a bit higher.
-Bought a 2nd set of wheels/tires: IMEX Claw Dawg tires and Traxxas 2.2 hex rims.
-Changed to ball ends on the front tie rods
Future modifications:
-New Era Models roll cage (sometime soon)
-New wheels (chrome) with Proline Masher 2000 tires
-10x15mm bearings at each axle
-125cc tank for long run times with the OS CV-Rx .15 ( should be in the 20 minutes + range)
Overall observations:
The MT2 has proven to be a pretty durable truck. I have done many flips and tumbles with the truck and other than stripped spur gears the only part I've broken was the front lower a-arm and that was my fault for running it into an immovable object.
The truck has excellent handeling on the ground. It corners with much more speed than a T-Maxx and doesn't roll over nearly as much. Jumping is a bit more tricky with the MT2. Since it has a shorter wheel base and large tires hitting the throttle or the brake causes much greater movement in the air than it did on my old T-Maxx. This can cause nose up or nose down landings. Smaller tires help with this a lot, but then you loose some of your MT look and ability.
I would like a bit more on power steering out of the MT2. I'm not talking about full power steering as no RC car has much steering while at full power. I'm talking about 1/4 power steering. The only time I can get even a semi-tight turn out of the MT2 is when I'm off power and hitting the brakes lightly. My old T-Maxx could turn tighter turns than my electric buggy and I miss that in my MT2. Looking at the steering set up it doesn't appear that there is much that can be done with this unless there is a complete re-design of the steering.
Fuel consumption is very good with the MT2 regardless of whether it was with the NT-16 or the OS CV-Rx. I get a good 10 minutes of run time out of both motors. This is about 2 minutes longer than on my old RC10GT per tank.
Acceleration with the MT2 is brisk with the stock tires on it. It could however be better. Some clutch modification could make a big difference in acceleration with the bigger tires. A slightly stronger spring would delay clutch engagement and put the engine into it power band before it starts moving. With the IMEX Claw Dawg tires it accelerates extreemly quick. This lowers the gear ratio and has less rotational mass. With the IMEX tires on I also have a very hard time flipping the MT2 (not that I want to). I'm able to sent the MT2 into power slides on pavement, hit the throttle and pull out of them with all 4 wheels spinning like crazy.
Top speed is as advertised. With the stock tires I can see 45mph out of the MT2. With a .21 the MT2 is insanely fast in both acceleration and top speed (one of the threads in the normal MT forum has a video of the conversion and it flat moves out).
Maintanence has been fairly easy on the MT2. Changing a spur gear however is a pain in the butt. You have to take the rear end off of the truck, dissasemble the rear differential, then take the transmission apart which isn't all that easy, then put it all back together. This generally takes a good hour to do. Other than that the truck is pretty easy to work on with things well laid out.
Overall, I'm pretty impressed with the MT2. It still needs some work, but out of the box has no more problems than any other MT out there but for $100.00 + less than other MT's.
