I have 2 noval 5300 Super sport Brushless motors & one monster truck txt equal. I am wanting to install, but the novak website suggests not using these.
Due to me being in area limited in not getting new stuff fast. This is all I have to work with.
What do people think of this system as a dual motor set up in a monster/ 4wd stadium turck.
i think using two of those motors would be ok in that truck. or you could sell those motors and buy a novak 4300 or two which is specifically made for monster trucks
First and foremost, the SS4300 is NOT for monster trucks. It is a Brushless "Stock Motor" equivalent. NOT FOR MONSTER TRUCKS.
Just so I can try to avoid further confusion, what led you to beleive the SS4300 was a monster truck motor?
The Super Sport system that is currently available is not suited for monster trucks as a "single" system. Most folks that have tried two have been pleased with performance as it is twice the power of one system. Dual Super Sports is not as powerful as what the HV-Maxx System will be (See our website for details), but it will work okay. In the TXT- we ran a single SS and it is halfway decent, just gets too hot to be used regularily, dual would be a different story. I have not run dual Super Sports in the TXT, but I have in the E-Maxx and it the systems will be slightly better than the stock Titan setup.
so can lingth is not in any way related to torque? im sorry, i thought it was. but why do the 550s in a emaxx have more torque than a 540 of the same wind? they have longer cans.
Originally posted by baih longer cans means longer magnets. stronger or bigger magnets makes stronger motors.
But you can get super strong magnets in a 540 can as well.
550 use a larger armature, which also more flexability in motor design, and more voltage to be used if required. Too bad no motor manfactuer has taken advantage of this though.
Originally posted by Hairball But you can get super strong magnets in a 540 can as well.
How you figure? the novak HV is basically a 550can
Hey Bob trying reading either slower or more carefully. If you look on that site under the HV-maxx where you can click on the SS BL system and the SS4300 motor this is what it says right above these two links:
The HV-Maxx High-Voltage Brushless Motor System will be available soon. Please keep posted for updates. For information about our other brushless motor systems click on either of the following links:
Now is it clear to you or what. The SS4300 motor is for use with vehicle such as TC's that are lighter and don't want to have the blazing speed as the SS5800. It is close to running a stock motor. It is not designed for MT's even small MT like a Stapede I wouldn't try it in.
