Thanks Sandman
Thanks Sandman,
I heated the stock gearcover with a bic and then pushed the plastic out, and now no more rubbing, it was brand new by the way.
We will try the 18 tooth pinion as the starting point, much appreciated, are you running the controller in unlimited or are you using one of the limiting modes (45amps or 60 amps)? and along the same lines are you in timing mode 1 (2-5 degrees) or mode 2 (10 degrees)?
Thanks again for sharing!
Signats
