im going to get a brushless for my Tc3 and im not sure which brushless setup to get so should i get a Novak Super Sport or a Hacker C40 6t w/a Master Car Sport controller? Im looking fpor the motor that has the highest rpm's. so any help?
Well, its hard to say, but the 6T would probably be around 5-10 mph faster, I think. You'd probably be doing around 40-45 on 6 cells, but you could probably go up to 8-10 if you wanted to.
I am not sure about the exact gears to use, but this is how I'd gear it:
Start out how you'd gear a 10 turn motor, if you would like more top speed, gear up to a 15-19 turn, and then up to a stocker if you want.
Basically just start really low, and work your way up.
I think the 7018 warrior is a bit too weak for the 6t. I`m running the 6t on a shulze 12.97 esc, and it gets hot enough(it is 97A, and the warrior is 70A).
I actually ran the 6t on my 7018 warrior too, but it had a meltdown, so that`s when I got the Schulze. The schulze is also a lot smoother on the throttle, and doesn`t need a rx pack to prevent cogging which is very nice
