BL Differential setting?
I just got done rebuilding the diff in my BL T3. It was starting to make clicking sounds. I replaced some of the worn parts and it works great now. The manual says to adjust the diff a certain way and not to ever set it any differently (bad pun intended). I, however, run my diff on the tight side due to the higher rpms and torque of BL motors. I set it as if I was running a lower turn brushed motor.
What's the best way to set a differential gear when running a BL motor? Thanks!
