In my previous post I mention the fact that wheel spin may account for some of the speed. That is why I am hesitant to get too fired up about the speed. I am aware of the problems with calculating speed by wheel rotation. I am building a slave wheel system like used on full size cars that will trail behind and give me better top speed info. That will be alot better.
I mounted two fans against the motor, one over the top and one on the side. There just so happen to be a couple holes that perfectly line up with two fan mounting holes. So, I used those for the top fan and double sided foam tape to hold the other fan.
I finally have the body mounted (Protoform Stratus). I extended the foam bumper to perfectly fit the inside of the nose. This will prevent body deformation at top speed.
I am also shifting my intent of this project. I am no longer going for absolute top speed. Now I am pushing to make it as fast as I can while retaining driveability and reliability. I recalibrated my VSM and My Eagle Tree. The car is running consistant 94 to 96 MPH. I have a new pinion on order that will push that to about 106. That will be plenty for me.
One reason I am not too freaked out about the wheel spin issue is that the car tops out and still has room to go while wound out. It hits full speed and I have about 1.5 to 2 seconds of time with the car wound out. So, I am assuming any wheel spin has settled down and I am getting a relatively reasonable idea of the top speed at that point. If it is still wheel spinning, then I know all I need is a little more room to let it wind out. But, judging by the sound of it as each run progresses, it sure "Sounds" like it is totally wound out. A radar will be the confirmation of that. But, I want to get my new pinion to get it well over an indicated 100 before I have it radared.
I am not pushing for any world record. I just want to see 100.
Matt
