I think this concept is way cool!
But why don't you just use the housing of the turbo where you got the turbine from? Was kind of expecting to see that in these new pics.. Wouldn't that be easier and probably more effecient?
Should be easy enough to connect the jet engine to the intake, and the exhaust would come out in the direction of the axl. Connect a bent pipe upwards and you're done!
Just a thought...
Good luck building!
Hz-R: The housing of a turbo weighs about 10 lbs and does not
have enough room inside of it for the amount of air comming
out of that turbine.. basicly its to heavy and too small..
The turbos on normal car engines aren't that big, and I guess a normal car engine propably puts out quite a big amount of hot gasses at full throttle. That's why I thought that would be the way you're going.
Then again, I don't have any experience with jet engines, they probably are very powerful and the added weight sure is a factor!
Can't wait for the first 'test report'
Happy weldin'!
Another problem is I want to be able to have the car sitting there with
the turbine running at idle. Even at idle it still turns 35,000 rpms and
moves a lot of air... With my hosed up design that air will just go around
the turbo, but if I forced all that air into a turbo with a housing it will
most likely back pressure the turbine and overheat it..
My plan is to run it like this... cool and safe... then install a adjustable
plate just behind the turbine to deflect the hot air down..
This will force more of it to the bottom half of the turbo... if I force to much
it may run hot... The key is to make it adjustable..
Ah, didn't think of that, you've obviously thought this out more then I have! ;-)
With a turbo housing you would then some sort of valve as well, which would add even more weight..
It's pretty much all pioneering work you're doing there anyways, trial and error.. If you get it to work, this thing will surely scream!
Every thing that goes in the car is in the pics.. It runs more like 600 C,
that is why the box houseing is all Stainless steel. I am just going to cut
a large hole in the back of the car body to let the exhaust out and a few
smaller ones for the intakes...
If it the box housing heats up the car too much. I will install some Stainless Steel
foil around that housing. I may even attach a small fan to one the drive shafts
to make it self cooling...
I think it will be fine... I have installed turbines in all foam airplanes before.. no problem
I bet that thing is going sound awesome...just the freakish high speed whine of the turbine. Man, when you get it finished and do a test run on video, don't add any music to the video.
Yo eddy I aint been around much lately buis keepin me away..but man you got a sweet idea on hand...Im thinkin...wastegate...have the turbine and a titanium tube with a servo that will work sorta like a nitro carb...let just enough air through but not enough for it to move...hit the throttle and open the gate and boom all the air from the turbine rushes through sendin that sucker 175 mph...LOL...Im gonna draw up what im talkin about tomorrow mornin and let you see what im really talkin about...i love the idea and the skills you are showin...thats awsome!
It was mostly an educated guess, but transfering kinetic energy to mechanical energy is a huge loss.
Anyway, I wish I had a turbine to play with!!!!!!!
Your tunnel that your thurst is going through, might want to be just barely slightly larger than your turbine gear fins, to make sure you can capture as much thrust as you can into the vanes.
