Old 09-02-2004, 09:12 PM
Man oh man the slowness!
Well, i hooked up my venom speed meter to my CEN ct4-s, with the OS .21 rg-x, now i thought a bigger engine with more hp, and more rpm's would launch this thing better then the stock (.9hp, 28,000max claimed 73mph), i found out today that it could hit 42mph max! That sucks! I know the speed meter has some flaws in accuracy, but it should do inreality 75-80mph right?
Anyways i had a full block to accelerate and brake, i heard the engine rev high, but it could be that the second gear is not engauging (its a clutch style and its hard to hear the shift)
Does anyone have any suggestions on what i could do to get more speed out of this engine, and if it was a good idea to go to the .21 on this car?
Thanks!
Old 09-03-2004, 12:05 AM
Crashmaxx Crashmaxx is offline
It may be that it isn't hitting second, but it won't go 75-80. That claim from CEN is all BS. I would expect 60 at best, and with that motor, it sounds a little slow, but it could just be geared poorly. Your speed meter could easily be off if not set properly, but not by that much.
Old 09-03-2004, 02:38 AM
but on CEN's website there was the radar and everything, that engine was a good engine so i think it was possible for it to hit 70ish.
Anyways would you have any suggestions on a newer engine that would put out pure speed? Cen said that this gearing was made for TOP SPEED, and the gearing that i could advance to for top acceleration i tried already, anyways any suggestions?
Old 09-03-2004, 02:55 AM
lalala lalala is offline
http://www.radiocontrolzone.com/foru...d.php?t=159534
Read his review from above link. I think you two using the same speed meter too. A few members on this board alrady achieve 70+mph out of box. I plan to be next. So i would assume you doing something wrong. I would say its either not hitting 2nd or that engine is just not as good as the stock engine or maybe ur tire just sucks. BTW, according to CEN site, CT4s have like 35000RPM so ur got the wrong figures
Old 09-03-2004, 03:20 AM
well acording to the manuel that came in the box it says NX-15, 0.9hp @28,000 rpm. And according to this guys readings he hit around 28,000 (29,557) and not 32,000, or it could just be it had a max 32.000 and he could only hit 29k.
This MAY be their old figures (for my engine), but i dont know... this whole clutch style 2nd gear shift is a little harder to tune than a finger style 2nd speed clutch. I will take it out tomorrow, and for the speed meter, use mm instead of inchs to get a more accurate input and then convert the kph to mph after.
But when i lifted the car and had it free wheeling (i know, i know VERY bad idea for the engine) but i hit 64 at 70%throttle, and i FELT it hit 2nd gear when it got to 50mph. This is however with the wheels free spinning.
Thanks for your thread link, it was helpful and i got in touch with the guy...
thanks!
Old 09-03-2004, 04:07 PM
nitrohead5300 nitrohead5300 is offline
You should hear it when it changes into second regardless if it is a claw type 2 speed or clutch type you should hear a change in pitch. The OS motor you have is a good work horse motor but it is down on power you might want to up-grade
Old 09-03-2004, 05:49 PM
WS7er WS7er is offline
That motor isn't a high reving engine. HP rating are BS, unless there all done by the same exact dyno, with the same exhaust, which I HIGHLY dought. If you want to run really high speeds, you have to get an on-road engine, the OS rg-x is an offroad, which wiill turn alot more rpms.
Old 09-03-2004, 05:50 PM
Oh so i SHOULD hear it change? thats what i thought but tons of people told me its such a subtle change that you wont hear it. So i will lossen the springs of it to where i can hear it change at mid-high rpm's.
Now the OS .21 WAS my UPGRADE... therefore i spent all my money saved up on it. If you were to suggest an engine better than that with a budget of 100-230(MAX!) what would it be?
OH! regardless of it being an off road engine, would it not still send my car faster than 42mph? (using a CVEC 21 pipe), Or is that reading correct?! I really thought putting in a bigger engine with more rpm's would send it past a smaller engine with less hp and rpm's, this now makes me a noob...need help...fast!
Old 09-03-2004, 05:52 PM
well, what engine size? .21? .12, .15?
Old 09-03-2004, 05:56 PM
for my car? it can handle any engine .12-.28, you tell me what you had in mind for a "better" engine.
thanks alot for your help
Old 09-03-2004, 06:07 PM
You can get .12 engines to rev high also. Right now. Nitrohouse is having a sale on there JP Modified .12 5 port race engine. The stock one revs to about 44,000 rpm, and the JP modified one has been ported and polished, and has a special coating on the crankshaft pin that is slippier than teflon, and the crank has been drilled out and filler with epoxy which lightens the crank, which increases the acceleration alot. So I think that engine can rev forever. I have seen it run personally, and it seems the RPM keeps going up. Can probably go 46,000+ rpm. Right now it is $299. If you want to get into the hi-end .21 onroad engine, it will cost $350-$1000. Bigger engine make 2-3x the torque of the .12 size engine, which means you can gear it up high, but with the .21 onroads, they rev 43,000+ rpm, with the same 2-3x the torque.
Old 09-03-2004, 06:27 PM
So better to go with a small block for my budget. What do you think would be the speeds of it, if the stock can hit AROUND 70mph?
Old 09-03-2004, 06:29 PM
is this what your talking about?
http://cgi.ebay.com/ws/eBayISAPI.dll...ayphotohosting
Would you suggest then, i sell my NTC3 (brand new kit version that i put together, comes with some hopups), with a fantom fr15 engine, and airtronics reciever (no transmitter), and save up for the jp modified turbo? or just shut up and be happy with what i got?
thanks!
Old 09-03-2004, 07:08 PM
Yes, that is one of the best .12 out there now. Go to www.jpracing.com. They have pics of them. Also take a look at the onroad .21. The other one I was talking about is a www.nitrohouse.com, under the blowout sale. Another website is www.rc-mushroom.com. They sell the new MAX Power .12 modified. They has a 7 port .12 that is supposed to be BALLISTIC!
Old 09-03-2004, 07:13 PM
So....THIS would be better than the jpracing one?
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WD1V
Its a good price but it is also a 5port.
Now between the jp modified one and this one (i want to stick with paypal payable methods, its easier for me) nitrohobbies takes paypal, and on ebay too.
So between these 2, which would be my best bet?
And to do this i need to sell my ntc3, that i told you about, do you think its worth it, i am in a tug of war with myself about this because its a new car, with a nice engine FR15, BUT if this engine your talking about can BOOST my CEN CT4-s into outer space then i think its worth it. but if it adds like a little more power not that much noticable then i might have to pass, you know what i mean?
Old 09-03-2004, 07:18 PM
Well, I don't think the stock revs that high, because it is a sport engine. .12 is alot easier on the budget. The most expensive .12 is the JP Mod FX 12 05T 5 port. That is a very good buy on e-bay. They usually run $390-$460. The most expensive .21 onroad engine right now is the JP Mod FX 21 R-02 8 port race. They run for about $800-$850. If I was in your position, I would get the JP FX 3 port. I would soup up one car to the limit, then has 2 cars that are intermediate with performance.
Old 09-03-2004, 07:24 PM
well i need to sell to buy, so if i were going to buy a new enigne i would have to sell the ntc3. and possibly the OS .21 (to go towards a starter box). That 5 port max on ebay is a MODIFIED engine, by the same guy as the 7 port, but if you think the JP is for me, then i CAN use nitrohouse because they DO take paypal, which means i would pay $300 for the engine.
You just replied before me. I would keep an eye out for the JP FX .21 5 port. The JP engines have a special coating on the crankshaft pin that is slippier than teflon, so the enigne will last a very long time. The Massinio Fattini Modified MAX Power 5 port doesn't have the special coating on the crank, which is the dissadvantage.
Old 09-03-2004, 07:30 PM
did you mean fx .21 5 port or .12? sorry i feel like i am being such a hassle with all these questions. IF you mean the nitohouse blowout sale engine, which is the 5 port .12 then i WILL go with that then.
thanks for all your help
That JP on Nitrohouse is a VERY Good steal. It is one of there flagship engines. The regular price for that engine was $459 at my LHS. It is a real screamer. So you can choose between the two. The JP 5 port at Nitrohouse, or the JP FX on e-bay. They both will rev extreamly high, and both have the special coating on them. One last thing. The one on nitrohouse is one of the old ones JP used to modify, but don't anymore. So parts for that engine are difficult to find, but you can use the same piston/sleave/rod/crank from the new JP FX.12.
Old 09-03-2004, 07:34 PM
Also, the JP engine that are on the JP website are the entirely new series of engines, the FX series, with the blue engine head. The one you see on nitrohouse is the one JP orderd from Novarossi, and just modified them. They don't do that anymore. JP's new FX series is engine with the blue engine head,built to JP specs, and modded by JP.
Old 09-03-2004, 07:39 PM
yeah on ebay those new fx series go for like $700!! on ebay! so i fear what they are retail. well i will put a slighly ridiculous reserve price for my ntc3, hmm $320? and IF i sell it then i have enough to play around with on the 2 engines.
thanks for all the help and the posts booster! 259 posts! yay!
Old 09-03-2004, 07:48 PM
The JP .12 on e-bay that you were looking at is also a FX series engine. They also make off-road buggy engines, and as you have seen, the .21 on-road. The .21 FX you saw on e-bay is actually the cheaper of the 3 .21 JP onroad engine. The JP FX21 R-02 has an Aluminum Sleeve, and 8 ports, and it runs for about $850. So it is either a win/win decision. The JP FX 3 port has performance of the JP FX 5 port, but the 3 port has better fuel economy, and the JP on nitrohouse is just about the same as the JP FX 5 port.
Old 09-03-2004, 08:08 PM
nitrohouse it is then, this WILL increase my speed right?
Old 09-03-2004, 08:13 PM
Well, an engine spinning over 45,000 rpm, it WILL increase the speed alot. Also, what scale is the car?
