Latest press release...<BR><BR>Racers Edge is proud to announce a Brand New .32 cubic inch (5.2cc) Nitro Engine!
The New SF5.2 Engine is based on a proven & very reliable power plant. It has been engineered and tested by the Racers Edge R & D department to be very easy to tune. Plus the big bore SF5.2 packs INSANE amounts of power! The engine comes with pull start and a non-pullstart back plate to easily convert for bump starting. In addition aftermarket shaft start systems are compatible. The black head and crankcase color will look good with any color anodized chassis parts. The engine is perfect for Buggies, Truggies, Monster Trucks and more!
For information and a chance to WIN ONE FREE go to
www.racers-edge.com
*Prototype engine shown, actual engine appearance will vary.
• Fits in any standard .21 or greater engine mount
• ABC Piston & Sleeve Construction
• Composite Carburetor for consistent tuning
• Will accept aftermarket shaft start systems
Part # Description
RCESF10000 .32 SURE FIRE NITRO ENGINE
www.racers-edge.com
Expect nothing less than the best from Racers Edge!
*****Just got the full specs from Racers Edge, plus a new photo (you already noticed that, right? Here ya go...<BR><BR>NEW RACERS EDGE SURE FIRE .32 (5.2) ENGINE SPECS:
Part Number: RCESF10000
Description: .32 SURE FIRE NITRO ENGINE
Horsepower: 3.6
RPM: 38,000
Engine Size: .32 cubic inch (5.2cc)
Sleeve: 8 port
Bore: 19.5 mm
Stroke: 17.5 mm
Crank: SG Type
Construction: ABC
Weight: 450 g (w/pull start)
Carburetor: 9 mm composite slide (with 8.5mm & 8 mm Carburetor reducers)
Carburetor adjustments: 3 needle, easy flush setting
Connecting rod: 7075 aluminum (Dual bushing)
Exhaust Type: Rear
Plug Type: Standard
Starting: Pullstart & Non-pullstart backplates included
The #1 most important performance factor is the INSANE amount of TORQUE!
For a chance to WIN ONE FREE go to
www.racers-edge.com
Ask your local hobby shop to get them on order as soon as possible!
The estimated street price will be about $199.99 on average, depending on the dealer.
Exclusively distributed by: HRP Distributing
2535 S. Decker Lake Lane, West Valley City, UT. 84119
1-801-978-9500
