Old 08-29-2005, 11:13 AM
PeterV PeterV is offline
pvieira(at)traxxas.com
Kyosho Mini-Z 4WD
Press release: <BR><BR>Kyosho announces AWD Mini-Z!
Kyosho, the world's leading manufacturer of radio control cars, reinvents the Mini class with the introduction of the new AWD Mini-Z. The new chassis, dubbed the MA-010, features an inline shaft-drive system that will elevate the performance of the Mini-Z to a whole new level. The added traction of AWD means it gets through corners more quickly and is able to run on surfaces that would easily trap a 2WD mini. The extra traction of the AWD is even further enhanced with new four-wheel independent suspension. The AWD Mini-Z also features many drivetrain improvements that make it even more efficient and the electronics have been upgraded.
The AWD Mini-Z goes back to its roots with the Skyline R34 body - the first shell offered on the Mini-Z when it was introduced. As the first AWD super car, it's fitting that it's once again installed on the first AWD Mini-Z.
• Shaft-driven AWD
The spur gear is mounted on a central drive shaft, which powers front and rear gear differentials. All the gears of the drive system and differentials are specially designed for maximum efficiency and durability. Even greater efficiency is accomplished by adding standard universal-joint driveshafts at all corners. Finally, ball bearings supporting the differentials make this machine almost as efficient as the 2WD machines.
• 4-wheel Independent suspension
Each corner of the AWD Mini-Z has kingpin-type independent suspension with coil-over springs, which means it soaks up the bumps better than ever. The universal-joint driveshafts keep everything running smooth even when the suspension is moving up and down.
• Upgraded electronics
The Mini-Z has a fully proportional electronic speed control with super-smooth acceleration, braking and reverse. The transmitter is full size for comfortable control, and its digital proportional, which means the signals are processed digitally. That means you have one of the most precise control systems available for high quality RC cars. The AWD Mini-Z features an RA-12 receiver/amplifier unit that handles 30-percent more power than the previous model, which helps to handle the extra power demands of an AWD system and optional motors.
• Adjustable front and rear toe angle
The new suspension and steering system of the AWD Mini-Z also allow adjustment of the front and rear toe angles. This simple tuning option results in better handling on any type of surface.
• Huge selection of bodies
The AWD Mini-Z is initially available with the legendary Nissan Skyline GT-R R34 V Spec, but you also have the choice of many other bodies already made for the MR-01 and MR-015 chassis.
Experience the excitement of AWD with the world-famous quality and scale appearance that is only available from Kyosho. The new AWD Mini-Z is the complete package for the Mini-Z performance enthusiast and it retains all of the features that make it the most popular line of mini cars in the world.
• Kyosho AWD Mini-Z
30560B - MINI-Z AWD MA-010 Chassis Set
30561MJB - MA-010 r/s Skyline GT-R R34 V-Spec II(Millennium Jade)
30561WB - MA-010 r/s Skyline GT-R R34 V-Spec II (White)
• Auto Scale Bodies
MZG401MJB - ASC Skyline GT-R R34 V-Spec II (Millennium Jade)
MZG401WB - ASC Skyline GT-R R34 V-Spec II (White)
• Chassis technical data
Total length: 127.5mm (M), 131.5mm (L)
Width: 65 - 72mm (67mm as equipped)
Total height: 43mm
Ground clearance: 4mm
Wheel base 90mm (M), 94mm (L)
Tread (F / R) 56.5 - 63.5mm / 56.5 - 61mm
Tire size: (F / R) 25×8.5mm/25×11mm
Gear ratios: 7.2/6.4/6.0/5.7/5.3/5.0/4.5: 1
Total Weight: Approximately 135g
Motor: 130 class
Old 08-29-2005, 11:19 AM
Silent Night Silent Night is offline
I never thought I would get another mini-z until now.. This is exactly what I have been waiting for!
Old 08-29-2005, 12:33 PM
TC4RACER TC4RACER is offline
whats the point? they must have made it to compete with the 4wd xmods
Old 08-29-2005, 12:58 PM
MT2 owns you's Avatar
MT2 owns you MT2 owns you is offline
i have to buy this!!!!!! how much is it? this thing is awesome!
Old 08-29-2005, 01:05 PM
TRF TT-01 TRF TT-01 is offline
Maybe I will buy a Mini-Z now since they offer 4WD! This is cool!
Old 08-29-2005, 02:47 PM
it looks like a great design but how much more can they cost? 150 bucks is alot for a mini car
Old 08-29-2005, 06:02 PM
munim munim is offline
Now THIS is what I have been waiting for, well actually, in offroad trim hehe.
Don't be so humble, you're not that great
The early bird gets the worm but the second mouse gets the cheese
Old 08-30-2005, 12:00 AM
rc addict's Avatar
rc addict rc addict is offline
wait a sec how fast do they go stock...what about upgraded? whats the fastest mini z anyones heard of?
Old 08-30-2005, 12:09 AM
^id like to know also^
Old 08-30-2005, 12:29 AM
um.. regualer ones go about 15mph stock.. the mr-02's.. I think the fastest one i've ever seen was 60.. might have been 40.. It was about 2 years ago i saw it..
Old 08-30-2005, 07:44 AM
DCLXVI DCLXVI is offline
Great, sonn I may have the 4WD OverLander I've been dreaming about
Old 08-30-2005, 08:00 AM
4wdmt 4wdmt is offline
...and also a 4wd mini-z mad force. what took them so long? lol.
Old 08-30-2005, 08:12 AM
JDAWG53 JDAWG53 is offline
Knowing Kyosho, this thing is going to be expensive. Cool, but no thanks.
Old 08-30-2005, 08:32 AM
Perhaps they wanted to cram out every last drop of money out of the MR-0x...the Iwavers did put some pressure on Kyosho I guess...
Old 08-30-2005, 11:21 AM
GRUNDIG415 GRUNDIG415 is offline
i have got to get one....
Old 08-30-2005, 01:08 PM
GTX's Avatar
GTX GTX is offline
HOOH HUAH HOOH! Aww Baby!
So where's the offroad version?
Old 08-30-2005, 01:11 PM
MikeWz's Avatar
MikeWz MikeWz is offline
Go Huge, Fall Hard
I'ma get one and paint it true "Bayside Blue Metallic"
Old 08-30-2005, 01:29 PM
Aluma's Avatar
Aluma Aluma is offline
YES!!! finally, not having to worry about the "ball diff" slipping or being too tight...no more spinning out during full throttle launches off the line... I bet this will be what lures racers into miniZ racing. .. If they come out with an evo 8 version..I am SSOOO buying it.!
TL01 rally
Old 08-30-2005, 01:55 PM
tracer tracer is offline
Any idea when we'll see these?
I tried out the 1/18th scale racing but it was just too big for indoor really.
Hopefully I can get into this and have some fun in the winter.
nitro.monster nitro.monster is offline
I foud this pics for about a year ago and I think it´s a 4wd kyosho mini monster. It´s look werry fun and cool
http://www.******.net/view_single.php?medid=64029
http://www.******.net/view_single.php?medid=64028
http://www.******.net/view_single.php?medid=64027
replace ****** with r c p i c s with out the spaces
Old 08-30-2005, 02:22 PM
Thats a xmod.
I can't wait!!! I doubt I'm going to be getting one for a while but I will! I need to fix my mr-02..
Does it come with a new controller? I want one like the Iwavers... I heard those have 3 model memory or somthing like that..
Old 08-30-2005, 03:23 PM
give your mr-02 to me
Old 08-31-2005, 01:19 AM
neongtr neongtr is offline
Finally, Kyosho do that.......the true Mini GTR R34
Old 08-31-2005, 02:06 AM
Silent Scope Silent Scope is offline
lol.. your kidding me.. u honostly think a xmod can compaire with a mini-z?
Old 08-31-2005, 02:25 AM
thedarkness thedarkness is offline
All this mini craze just reminds me of those little tamiyas everyone used to have that were like slot cars and rc cars put together.Mini4wds I think they were called, why dont they just stick a mini servo and some steering knuckles in one of those.
