Old 07-31-2006, 10:42 PM
PeterV PeterV is offline
pvieira(at)traxxas.com
Team Orion 3200mAh Carbon Edition Race Spec LiPo
Here's your first look at Orion's newest LiPo pack. The case has a humped design that emulates a side-by-side sub-C pack for a perfect fit in most cars. Kokam cells are inside the carbon-look case, and even though the pack is rated for 3200mAh, you can expect capacity comparable to a 4300 NiMh pack.
Official press release:
Because of the continuing success of the Platinum 4800 LiPo battery, Team Orion has gone back to the drawing board and created a version designed specifically for competition applications. The all-new Carbon Edition LiPo 3200 mimics the actual run times of today’s most popular competition NiMH cells, despite its lower capacity.
The Carbon Edition’s unique shape allows installation in vehicles that accept stick packs. Additionally, molded bumps along the battery’s underside lock it into position when used in slotted touring car chassis.
Features:
• 20C rated Kokam/Team Orion SLPB cells provide the safest output charge after charge
• Low IR, 3200 mAh capacity provides up to 40% longer run times than NiMH equivalents
• At 6.6 ounces, it is less than half the weight of a 6-cell NiMH battery
• 7.4V SLPB Kokam cells in a 2S-1P configuration paired with Team Orion’s exclusive PCB interface provides the lowest loss connection available with industry leading protection against damage
• Twisted gold plugs with Tamiya style connector allow for easy installation
• Cell balancing port
• Attractive carbon look case
• Excellent option for today’s high-performance 3D helicopters
ORI14001 Carbon Edition 3200 LiPo Battery Pack $119.99
<BR><BR>
Old 07-31-2006, 10:48 PM
metalry101's Avatar
Got Baja?
So what's the advantage? Less weight is nifty, but is this less expensive than the 4800? A lot less?
Old 07-31-2006, 10:49 PM
Dan-o Dan-o is offline
MSRP? street?
Old 07-31-2006, 11:05 PM
jocktheglide165 jocktheglide165 is offline
no way dude that rocks.....dang it now I want my lipos back...
Old 08-01-2006, 12:15 AM
tmacfan4321's Avatar
tmacfan4321 tmacfan4321 is offline
naw you want your bashing lipos, none of the carbon crap
im all for the look though
Old 08-01-2006, 12:50 AM
i dont understand it saids 3200mah, but it has same capacity of 4200nimh?
Old 08-01-2006, 01:20 AM
ryanD ryanD is offline
i dont get that in the middle on the bottom is flat for battery straps, if you put it in up side down how will you get to the plugs?
I took the line out about the "flat for a strap" thing. It can't be flat for that reason, per your very logical observation. I suspect the humps are not full-width simply because they don't have to be in order to locate the pack within the battery slots. --Pete
Old 08-01-2006, 01:25 AM
you would think that some engineering would be envolved with the making of this pack
Old 08-01-2006, 01:55 AM
EvaderRacer76 EvaderRacer76 is offline
SWEET!!! I hope it is a lot lighter (and cheaper) than the 4800...then I'll be sold..
Old 08-01-2006, 02:03 AM
metalry101's Avatar
Got Baja?
Ya, that is weird. It probably has the bumps on the bottom so that when it's placed in a sedan with a carbon fiber plate chassis with cutouts, it positions itself correctly, and stays in place more easily. At least that'd be my assumption.
Old 08-01-2006, 03:57 AM
GordonFreeman GordonFreeman is offline
We use about 1200 mAh for 5 minutes on our indoor dirt (http://www.rcperformance.com/) , high traction dirt. ROAR is a bunch of @#$$^s, let it go already. Sub-Cs are dead.
Plus MaxAmps has reasonably priced LiPos. Shop around.
Old 08-01-2006, 04:20 AM
man how light do you want it? LOL I thought the lipos were light enough.....
Old 08-01-2006, 08:55 AM
chilly4kc's Avatar
chilly4kc chilly4kc is offline
Looking at the new case design, I see they put the balancing port on the top now. Maybe too many drivers were getting dirt in the port when it was on the bottom and the pack was used in a touring car?
I also talked to Orion support last week and they said they are making a balancer but it was going to be about a year before that came out yet. Maybe putting the port on top is to make it work better with their balancer?
Old 08-01-2006, 09:50 AM
___rollin___'s Avatar
___rollin___ ___rollin___ is offline
The price should be about even with this pack considering it's the same kokam cells, and same configuration. But a little more of course because of the fancy case. They (the pack I linked)were about $100-110 before, so expect 120+ to be normal for these.
Old 08-01-2006, 09:52 AM
kvector kvector is offline
Originally Posted by PeterV
As you can see, the humps are flattened in the pack's middle, so your T4 or Triple-X battery strap (or cars and trucks with similar hold-downs) can still be used.
How do you access the plugs if you put it in upside down?
Kokam cells are inside the carbon-look case...
It's basically a sticker or screen printing on the outside of the plastic, just like Orion's charger. Almost looks like it will be heavier with all the extra shaped plastic molding in the case design, or is this intended to actually be a stronger or more durable case (like something that can help the lipos survive a high speed crash)?
Old 08-01-2006, 10:22 AM
NiMo's Avatar
NiMo NiMo is offline
The humps are to fit in the battery slots on the chassis (like your current NiMh pack), you can the hold it in the same way as your normal NiMh pack without is sliding out the side of the car.
This is something we have requested over at another forum site, along with a rounded shaped so it can fit more cars without modification.
Old 08-01-2006, 10:29 AM
chilly4kc's Avatar
I have the Orion 4800 and it works great in my T4 with the carbon fiber strap, but it doesn't work well with my Trinity blue aluminum battery brace since the brace has grooves in it for C cells. It looks like I might be able to use that Trinity brace again with this pack.
But I also ran into issues when I tried to install the 4800 into my TC4. However, this new pack design looks like it will eliminate that issue too.
The humps on the bottom will fit snuggly into the cutouts on the bottom of the chassis that is normally used to allow the C cells to sit into them. So now these humps will fit into that perfectly (most TC have these cutouts now).
The top of the case it sunken in too, so that will make the battery strap fit better too since it has grooves in it to fit snuggly against a C cell pack.
So I can see why they made these changes. This pack design will fit into more RC vehicles now. And the more applications they can fit these pack into the more people will run them, and the more they will become accepted.
The only thing I don't understand is why they lowered the mah from 4800 to 3200? Maybe they are trying to get this approved by ROAR and they want to match the runtime of the best 4200 NiMh to keep things more fair? Kind of like running brushed and BL together?
Of course, the lipo is 7.4v and not 7.2v so it will always have a little more punch to it.
Old 08-01-2006, 11:42 AM
micros_rock micros_rock is offline
Rick said 80-90 for the price.
Old 08-01-2006, 12:57 PM
JakeE JakeE is offline
It seems these are newer cells than those currently being used in the 4800 pack. This pack is a 2s1p whereas the 4800 is a 2s2p. The 4800 pack is rated for 15C continuous, 20C burst - if this new pack is rated similarly that would only be 48A continuous, 64A burst. Hopefully these are at least 20C continuous cells. It's a nice idea, I wonder how long before manufacturers start designing chassis' with LiPos in mind.
Old 08-01-2006, 01:18 PM
JCSS JCSS is offline
So is this pack a 3200, or a 4300?? Are they just understating capacity to overstate discharge? Why not just state true capacity and discharge?
Old 08-01-2006, 01:28 PM
The bit about 4300 NiMH mAH equivalency is probably targeted towards the bigger is better crowd.
My understanding is the higher the discharge capability of the cell, the lower the IR the cell has. Thus, a higher rated cell will maintain higher voltage under load and therefore require less amps to perform the same job which equates to more efficient use of available capacity.
I may be completely wrong on this so please correct me if that is the case.
Old 08-01-2006, 02:58 PM
Rick Hohwart Rick Hohwart is offline
They are 20C continuous.
The rated capacity is 3200. But due to a LiPo's effeciency, this capacity translates to actual run times that are at least equal tot hat of NiMH cells with capacities of 4300 mAH
Old 08-01-2006, 03:49 PM
So what you are saying is, if i dicharge that pack at 1C, 3.2 amps, it will only put out 3200 mah?
Old 08-01-2006, 04:38 PM
Capacity is capacity. It does not change. A 3200 will always have less capacity than a 4200, regardless of construction
Imagine a 3200 unit "tank" full of LiPo draining to the motor though a solid pipe. A 4300 unit "tank" full of NiMh drains to the motor thorough a porous pipe. The motor sees the same amount of each because one loses much more on the journey to its destination. In reality, the loss is due to internal resistance, which surfaces as heat.
This is also true when comparing NiMH. A cheap generic stick pack with 3700 mAh cells holds the same capacity as a pack of GP3700s. But in no way do they perform equally, even though though they are the "same". The chape packs gets hotter with less duration and less power.
Old 08-01-2006, 05:27 PM
So your new 3200 mah pack, which only has 3200 mah, puts out more current, and also runs longer than a 4300 mah ni-mh that has over 25% more capacity. I think i get it now.
