Latest from www.teamnovak.com
ROOSTER REDUX: RESURRECTING NOVAK’S BESTSELLING ESC
Irvine, CA – October 19, 2006 – Novak is resurrecting the Rooster! For nearly 14 years, the Rooster Reversible ESC ruled the roost. Hobbyists not only appreciated the low-cost sport ESC, they appreciated its quality and durability. Now, after many years, Novak has not only decided to revisit this popular ESC, but make it better, stronger, and faster. Some would even describe it as…a bionic Rooster. This one, however, won’t cost you six million dollars!
While the new ESC retains the original Rooster name, there is not much resemblance — inside or out — to the original Rooster. Externally, it is apparent that the Rooster now sports a modern outer casing, and consequently, a smaller footprint. It also sports a new heat sink assembly and 14-gauge power wires on PCB-direct solder tabs, making soldering extremely easy.
Internally, the Rooster has also undergone some technological advancements. This more powerful, robust ESC can now handle motors down to 12 turns, where previously it had a 15-turn limit. This extra power, plus a new heavy-duty, 6 Volt / 1.5 Amp BEC adds to its durability, making it ideal for those running modified motors. Its power and performance solidly places the newest addition to Novak’s Reversible ESC line between the #1830 XRS Sport Reversible, and the heavy-duty, high-voltage
#1865 Super Duty XR.
When the original Rooster debuted way back in 1993, it was Novak’s first ESC with the now standard One-Touch Set-Up feature. The new Rooster 12T has the honor of being first again with another great new feature: built-in Li-Po cutoff protection. Novak’s newest technology monitors the vehicle’s Lithium Polymer battery pack’s voltage, and prevents the batteries from going below the critical safety voltage level. The driver is cued via throttle blips when the voltage drops to a certain level. It then shuts off, however, full control of the steering servo is left intact. The Li-Po cutoff protection feature can be utilized in two of the four throttle profiles the Rooster 12T now has:
1. Forward/Brake/Reverse (Default)
2. Forward/Brake
3. Forward/Brake/Reverse with Li-Po Cutoff
4. Forward/Brake with Li-Po Cutoff
Other new features include Smart Braking II, a water-resistant case, a user-replaceable input harness, Direct-Solder Wiring Tabs, and auxiliary fan connectors. While the Rooster 12T has been infused with many new features, it still includes all the great, standard features for which Novak is known, such as: One-Touch Set-Up, Radio-Priority Circuitry, Polar Drive Circuitry, Thermal Overload Protection, and of course being designed and manufactured in the USA.
The #1840 Rooster 12T Reversible ESC will be available December 2006. The retail price is $149.
ROOSTER 12T REVERSIBLE ESC FEATURES
• Operates down to a 12-turn brushed motor
• 4 Driving Profiles
• Built-in Li-Poly Cutoff Protection (2 Driving Profiles)
• Reverse Disable (one with Li-Poly Cutoff)
• Smart Braking II
• Water-Resistant Case
• Direct-Solder Wiring Tabs
• User Replaceable Input Harness
• One-Touch Set-Up
• Built-in Power Output for Optional 6V Accessory Fan (#5648 or #5646)
• Radio-Priority Circuitry
• Polar Drive Circuitry
• Thermal Overload Protection
• Designed and Manufactured in the USA
ROOSTER 12T REVERSIBLE ESC SPECIFICATIONS
• Forward/Reverse Forward and Reverse
• Input Voltage 4-7 Ni-Cd/Ni-MH cells (1.2V/cell) or 2 Li-Poly cells
• On-Resistance 0.0014 ohms (forward); 0.0028 ohms (reverse)*
• Footprint 1.54” x 1.18” (39 x 30 mm)
• Weight 2.66 oz. (75.5 g) w/wires; 1.57 oz. (44.5 g) w/o wires
• Rated Current 400 amps* (forward)
• Braking Current 200 amps*
• Power Wires 14-Gauge
• BEC 6.0 volt/1.5 amp
• Motor Limit 12-turn brushed (at 6 cells Ni-MH)
• Discrete Steps 256 Forward; 256 Reverse
• Battery Plug Tamiya
• Motor Plug Bullet connectors
• Drive Profiles 4
--FWD/BRK/REV (Default)
--FWD/BRK
--FWD/BRK/REV w/Li-Po Cut-off
--FWD/BRK w/Li-Po Cut-off
• Status LEDs 2
• Voltage Cut-off 6.25 volts (Li-Poly Profiles)
*Mosfet rating at 25 C junction temperature
