Latest from www.hpiracing.com
Have you ever experienced the excitement of a monster truck rally? Here's your chance to bring that excitement home! HPI is proud to announce the release of our newest addition to our electric monster truck line, The Wheely King! As the name would imply the Wheely King is designed with the wheelie in mind, perfect wheelie-tuned weight distribution and rear wheelie bar allows you to pull an all day wheelie and also bash with the best of them.
Realistic looks add to the monster truck experience with features like Tough TVP (Twin Vertical Plate) chassis with tube frame design. Front and rear solid axles with pivot arms and center gear box also add to the realistic driving experience and scale looks. Included in the package are realistic chrome wheels and new 5.4" Mud Thrasher tires, and an adjustable design that makes mounting your choice of bodies quick and easy. The 1/12th scale size of the Wheely King is perfectly suited for the back yard basher with features such as 4 long stroke oil-filled shocks and coil springs with 6" of suspension travel for all-terrain driving, adjustable gear mesh that allows a variety of gear ratios, flexible drivetrain layout allows for the use of all popular 7.2 volt batteries and 540 size motors. The simple and durable design of the Wheely King allows for ease of maintenance and the ability to soak up almost any kind of abuse you can throw at it.
Highlights
1/12th scale size is perfect for backyard driving.
True-to-scale monster truck looks.
Designed for easy maintenance and durability.
Full Ball bearings for efficiency and long run time.
Includes
TF-1 High quality 27MHz transmitter
Fully proportional steering and throttle
Reversible electronic speed control
High torque 540 motor (27T)
7.2V 1500mAh Ni-Cd battery
Clip-on molded nylon cover for gear protection
Quick-change battery slot
Efficient sliding center universal drive shaft
Wall charger (120V)
Accepts popular 7.2V batteries, 540 size motors, and standard size electronics…
Easy to customize!
Clip-on molded nylon cover for gear protection.
Adjustable design makes mounting new bodies quick and easy.
Adjustable gear mesh allows a variety of gear ratios.
Electric powered for quiet, safe and easy operation.
Wheelie-tuned weight distribution and rear wheelie bar make wheelies fun and easy!
4 long stroke oil-filled shocks and coil springs.
Quick-change battery slot holds the 7.2V stick pack securely.
6" of suspension travel for all-terrain driving.
Efficient sliding center universal drive shaft.
Front and rear solid axles with pivot arms and center gear box for realistic driving and scale looks.
Realistic chrome wheels and 5.4" Mud Thrasher tires.
Because the Wheely King is 1/12th size, it's smaller than the 1/10th size E-Savage and it's just as fun! The Wheelie King can be easily driven indoors because of its smaller size, but it's also perfect for fun in the garden and even out on the racetrack!
LENGTH: 431.8mm (17in.)
WIDTH: 297.2mm (11.7in.)
HEIGHT: 254mm (10in.)
WHEELBASE: 238.8mm (9.4in.)
TIRES: 135mm x 69mm (5in. x 3in.)
SUSPENSION TRAVEL: 152.4mm (6in.)
Option parts already available:
http://www.hpiracing.com/options/en/10820.html
#10820 WHEELY KING RTR TRUCK with MINI GT-1 TRUCK BODY EAN #4944258108209 $335.00
