Old 03-28-2007, 04:31 PM
MattHiggins's Avatar
MattHiggins MattHiggins is offline
Novak EX Brushless Motors
#3430 EX8.5 Extreme Sport Brushless Motor
#3431 EX10.5 Extreme Sport Brushless Motor
#3432 EX13.5 Extreme Sport Brushless Motor
#3030 XBR Sport / EX8.5 Brushless System
#3031 XBR Sport / EX10.5 Brushless System
#3032 XBR Sport / EX13.5 Brushless System
From Novak:
THE LOW-COST SOLUTION TO UPGRADE TO BRUSHLESS:
NOVAK’S EXTREME SPORT BRUSHLESS MOTORS
Novak’s brushless motor factory is working overtime making new motors. The newest addition to Novak’s brushless motor family is the EX Sport Brushless Motor Series. The budget-friendly sensored brushless motor series is ideal for R/C enthusiasts who have always wanted to join the brushless revolution, but have resisted.
With Novak’s EX-Series brushless motors, the time has come to painlessly make the step up to brushless and personally experience all of the things said about brushless, but just found hard to believe; things like: incredible power and starting torque, minimal maintenance, and longer runtimes.
Novak’s EX-Series Sport brushless motors are available in three motor winds:
 #3430 EX8.5 Extreme Sport Brushless Motor: 8.5 turns; similar to a 15-17-turn mild-modified brush motor
 #3431 EX10.5 Extreme Sport Brushless Motor: 10.5 turns; similar to a 19-turn brush motor
 #3432 EX13.5 Extreme Sport Brushless Motor: 13.5 turns; similar to a 27-turn stock brush motor
SPORT BRUSHLESS MOTOR FEATURES
Novak’s newest motors also sport a new look for a Novak motor and it’s golden. Literally. The EX motors break from Novak’s traditional purple motor sleeve with a new gold one. And while the EX Brushless Motors may be described as “sport” models, they still include all of the great features of a Novak brushless motor like a convenient Solder Tab System for easy wire replacement; Sensor-Based Technology for excellent starting torque, low-speed drivability, and smooth acceleration; Thermal Overload Protection (when used with a Novak brushless ESC) that allows pack after pack to be run without fear of damaging the motor, battery, or ESC; and approximately 20% longer runtimes compared to brushed motors.
A unique feature of all Novak motors is the ability to upgrade or replace various parts. Although deemed a sport model, the EX motors are no exception. Users are able to replace parts like the front end bell/bearing and rear bearing (#5905), as well as the rotor (#5906) if needed, and not simply toss the motor aside. Another option for the user is to upgrade the motor with a motor upgrade kit (#5923) for the pro performance of the SS-Series of motors.
Each EX Sport Brushless Motor is available separately, or in a combo system factory-wired with Novak’s new XBR Sport Brushless ESC (see separate press release). Like all Novak brushless systems, the brushless speed control and brushless motor are factory wired and tested together, and are ready to “plug and play” straight out of the box. The following three XBR Sport / EX Brushless Systems will be available:
 #3030 XBR Sport / EX8.5 Brushless System
 #3031 XBR Sport / EX10.5 Brushless System
 #3032 XBR Sport / EX13.5 Brushless System
ESC COMPATIBILITY
The Extreme Sport Brushless motors are compatible with all Novak brushless ESCs, including:
 #1720 XBR Sport Brushless/Brush ESC
 #1705 Super Sport Plus Brushless/Brush ESC (and original Super Sport Brushless ESC)
 #1710 GTB Programmable Brushless/Brush ESC
 #1711 GTB Spread Spectrum Brushless/Brush ESC
 #1714 GTB 4-Cell Programmable Brushless/Brush ESC
 #1715 GTB 4-Cell Spread Spectrum Brushless/Brush ESC
RETAIL PRICE INFORMATION
 #3430 EX8.5 Extreme Sport Brushless Motor $99
 #3431 EX10.5 Extreme Sport Brushless Motor $99
 #3432 EX13.5 Extreme Sport Brushless Motor $99
 #3030 XBR Sport /EX8.5 Brushless System $299
 #3031 XBR Sport /EX10.5 Brushless System $299
 #3032 XBR Sport /EX13.5 Brushless System $299
 #1720 XBR Sport Brushless/Brush ESC $219
The EX-Series Brushless Motors, XBR Sport /EX Brushless Systems, and XBR Sport Brushless/Brush ESC will be available May 2007.
EX-SERIES BRUSHLESS MOTOR FEATURES
 Sensor-based for excellent braking and low-speed driveability
 Provides approximately 20% longer run-times compared to brushed motors
 Specifically designed for R/C vehicles
 Minimal Maintenance
 Direct-Solder Wiring Tabs for flexible soldering options
 Thermal Overload Protection (when used with a Novak brushless ESC)
 No cogging for smooth acceleration and smooth coasting
 Ball bearings for smooth, low-friction operation
 Bonded Neodymium rotor (ROAR-Approved)
 User-replaceable rotor (#5906), and user-replaceable front end bell/bearing and rear bearing (#5905), and can be upgraded for race-ready performance, which includes Novak’s Sintered Rotor (#5923)
 Factory hand-wound and race-tuned
 Developed, manufactured, and tested in the USA by Novak
EX-SERIES BRUSHLESS MOTOR SPECS
 Turns: 8.5 (#3430), 10.5 (#3431), 13.5 (#3432)
 Design: Sensor-based
 Input Voltage: 4-7 cells (1.2V/cell or 4.8-8.4 total volts) or 2 Li-Poly cells
 Magnet: One-piece, bonded Neodymium
 Watts: 225 (#3430), 195 (#3431), 165 (#3432)
 KV (unloaded): 5,000 (#3430), 4,200 (#3431), 3,300 (#3432) RPM/Volt
 Resistance (m-ohms) 13.3 (#3430), 16.7 (#3431), 26.5 (#3432)
 Motor Size: 540 Size: 2.08” L X 1.41” D (52.8 x 35.8 mm)
 Motor Weight: 6.73 oz. (190.8 grams)
 Shaft Diameter: 0.125” (3.2 mm) [accepts all existing pinion gears]
 Front Bearing Size: 3/8”” x 1/8” (9.5 x3.2 mm)
 Timing Ring: Black
 Motor Sleeve Color: Gold
 Protection: Thermal
Old 03-28-2007, 05:26 PM
chilly4kc's Avatar
chilly4kc chilly4kc is offline
Interesting. Glad to see Novak is offering a low cost BL motor just LRP is doing with their Eraser series.
Old 03-28-2007, 06:06 PM
vaderbxman's Avatar
vaderbxman vaderbxman is offline
How much are they gonna charge? Because if it's still over 170, I'm not gonna be interested....
Old 03-28-2007, 06:08 PM
crazy4wdracer's Avatar
crazy4wdracer crazy4wdracer is offline
just what I needed!!!
Old 03-28-2007, 06:26 PM
Mini-TBasher55's Avatar
Mini-TBasher55 Mini-TBasher55 is offline
It might be around that price range.
I think that Novak needs to do what Castle does - something like the Castle Link. Can you imagine being able to have a version of the Mamba Max that has all the features, but is also sensored? That'd be pretty sweet.
Old 03-28-2007, 06:54 PM
SS Pede's Avatar
SS Pede SS Pede is offline
I am going to have SO much trouble explaining Novak BL motor options to people!!
Can anyone explain what makes these motors slower than the SS series? They are the same number of turns, but lower kV ratings. What is the mechanical difference that causes this lower performance? Different magnet?
Old 03-28-2007, 07:03 PM
Adanmtxt1's Avatar
Adanmtxt1 Adanmtxt1 is offline
Old 03-28-2007, 07:06 PM
I thought Tower had the ESC for $130...
EDIT: Yup, those prices are list. Retail is like this:
http://www2.towerhobbies.com/cgi-bin...?&I=LXRST1&P=7
Old 03-28-2007, 07:23 PM
Adanmtxt1's Avatar
Hey, all I am doing here is literally quoting was was printed in the release above. Seriously. Re-read it!
Old 03-28-2007, 07:25 PM
I know. I wouldn't expect much better out of you, nwb
Old 03-28-2007, 08:19 PM
CharlieS CharlieS is offline
These motors don't come with Sintered Rotors.
Old 03-28-2007, 08:36 PM
SS Pede's Avatar
Did the original SS motors like the SS5800 have the sintered rotor? I didn't think they did, cause the sintered rotor is an upgrade. But these motors are still slower, aren't they? Sorry...I'm just a bit confused.
Old 03-28-2007, 08:40 PM
They are virtually the same as the orignall SS, slower then the new SS Pro.
Old 03-28-2007, 08:53 PM
SS Pede's Avatar
OK, thanks Charlie. I had a feeling you'd show up.
Old 03-29-2007, 01:20 AM
jocktheglide165 jocktheglide165 is offline
thanks for the options....
Old 03-29-2007, 07:46 AM
ducklake1 ducklake1 is offline
So, what would be better in a e-maxx? 2 of these, or one of the HV's?
Old 03-29-2007, 08:01 AM
just an HV would do...
Old 03-29-2007, 07:01 PM
vaderbxman's Avatar
Well, if tower sticks to that price, I bet they'll sell like hot cakes. If I had the money to spare right now, I'd get the 15-turn version to drop in my evader......
Old 03-30-2007, 08:35 PM
sim600 sim600 is offline
Charlie,
What's with the new solder tabs?
Old 04-02-2007, 03:37 PM
They are just a bit easier to use. Putting wire "through" the hole is difficult for most folks.
The wires holes were often not cleaned out properly, and folks would Drill them out, this is bad as the boards are plated. The tabs are just easier to use when you move motors around or 'rewire' the car.
Old 04-02-2007, 03:56 PM
Toothypaste Toothypaste is offline
They probably aren't allowed to do so...
Old 04-02-2007, 07:59 PM
There wouldn't be any reason for them not to be able to. It's like saying that Castle can't use LiPo cutoffs. As far as I know, there is no patent or anything.
