Old 07-11-2007, 11:10 AM
PeterV PeterV is offline
pvieira(at)traxxas.com
Associated B44 4WD buggy NEW CHASSIS PICS
Latest from www.teamassociated.com. A four-wheel from the AE guys at last!
The Factory Team B44 project came to life in 2003 as a cooperative effort between Team Associated and J Concepts’ Jason Ruona and Brad Reelfs.
After Team Associated’s Ryan Cavalieri won the 2005 IFMAR World Championships in Collegno, Italy with the BJ4 Worlds Edition, Area 51 shifted into overdrive to produce a true ‘Associated’ inspired 4WD buggy that would continue to dominate the 4WD off road racing class. The B44 is the result of this two-year development effort.
During the design and development stages Associated used their extensive and well-proven skills to make a 4WD competition buggy that is better suited to production. The results of this optimization are realized by you, the customer, in a more cost-effective vehicle with more readily available spare parts.
The B44 is built on a 2.5mm woven carbon fiber main chassis and top plate. What’s new is the composite front bulkhead and rear chassis plate. These new features greatly improve overall durability and increase the ground clearance, further enhancing the B44's performance.
Area 51 designers also improved the BJ4’s slipper clutch. The result is the B44’s new externally adjustable, dual pad slipper clutch, which transfers power to the ground more efficiently and effectively.
The B44 employs a hardened steel CVA drivetrain with lightened ball differentials for unparalleled acceleration. The B44 soaks up the bumps using Factory Team hard anodized aluminum threaded shocks with gold shock shafts. The shocks mount to durable 3mm woven carbon fiber shock towers, making the B44 more responsive and giving quicker handling.
The B44 gets the full Factory Team treatment with blue titanium turnbuckles, blue aluminum shock bushings and blue aluminum servo mounts for a car that looks as good as it is fast!
Many Team Associated fans from all over the world have asked us when we are going to build a 4WD buggy. Team Associated is proud to say that day has come with the B44, the only 4WD electric race buggy that comes from a racing heritage with 20 IFMAR World Championships behind it
Features of the Factory Team B44:
• Composite front bulkhead and rear chassis plate for improved durability and more ground clearance
• Externally adjustable, dual pad slipper clutch
• 3mm woven carbon fiber shock towers
• 2.5mm woven carbon fiber main chassis and top plate
• Rear hubs use large .187 x .500 bearing for more durability
• Lightened ball differentials front and rear
• Shaft drive for unparalleled acceleration
• Slotted motor mount for quick and easy installation
• Blue aluminum center bulkhead cap with molded bearing inserts
• Ball bearing steering with adjustable servo save
• Hardened steel CVAs with cross pin retaining clips for ultimate reliability
• Front wheels and hexes are optimized to prevent hex stripping
• Hard anodized aluminum threaded shock bodies with Factory Team gold shock shafts
• Blue Factory Team titanium turnbuckles
• Blue Factory Team aluminum shock bushings
• Blue Factory Team aluminum servo mounts
• Blue Factory Team thumb screws and molded battery straps
This just in from Matt Higgins:
The B44 features a new steering system, hubs, slipper, bumper, gear cases, motor mount and a bunch of other new parts I'm probably forgetting. It looks dialed in person. Here are some "spy" shots I took.
Old 07-11-2007, 11:44 AM
TKCastle TKCastle is offline
Sickness! Now I know an AE truggy is on the way. I almost bought a BJ4, glad i waited.
Old 07-11-2007, 12:46 PM
B4 Stealth's Avatar
B4 Stealth B4 Stealth is offline
I have found my next car, this is sweet!!!! I can't wait for prices, anybody have an ETA? muahahahaha this WILLL bring the 4WD 1/10 class back in it's prime.
p.s.
Old 07-11-2007, 01:37 PM
YR4Dude's Avatar
YR4Dude YR4Dude is offline
Oooooooh! What a delemma! I was going to sell my B4 to get an RB5 to match my ZX5. Now I need to consider selling th ZX5 to match my B4 to this! Which way should I go???
Old 07-11-2007, 01:51 PM
YR4Dude's Avatar
This may be a deal breaker for me... What's the battery configuration? Is it single sided stick or is it saddle pack? If it is saddle pack then there is no chance of using a Lipo.
Old 07-11-2007, 02:14 PM
chilledoutuk chilledoutuk is offline
Erm there are saddle pack lipos and also you can make your own if you use the right cells.
http://maxamps.com/products.php?cat=54
Old 07-11-2007, 02:21 PM
YR4Dude's Avatar
Thanks. I've seen those and they're bulky. I doubt it will fit in the chassis let alone underneath the body. Also, I don't want to have two types of batteries to manage, saddle vs. stick.
Old 07-11-2007, 03:25 PM
crazy4wdracer's Avatar
crazy4wdracer crazy4wdracer is offline
looks good!!! I like the carbon towers!
Old 07-11-2007, 03:33 PM
vaderbxman's Avatar
vaderbxman vaderbxman is offline
When I first saw the title, I thought, "rebadged BJ4," but when I read that they refined the platform and added some features, I was impressed.
Cuddos to Team Associated!
Beware of the Large Box. It's known to eat small children.
Garage - Evader ST Pro, Evader BX Pro (currently in pieces) HPI dash
Old 07-11-2007, 03:35 PM
Emaxx321 Emaxx321 is offline
Nice.... about time really. Can't wait to see this in person. May have to finally part ways with the xxx4
Jon
Old 07-11-2007, 03:54 PM
ElectricThunder's Avatar
I like me.
At first, I thought the same thing (I just looked at the picture real quick). Then I read the whole press release, and it's like you said. They basically took the BJ4 design, tweaked it, added AE parts support and made the whole thing more mass production friendly. I can only imagine how much the Jconcepts guys made off of this.
"Let your reach exceed your grasp; else what is a heaven for?"- Unknown
Old 07-11-2007, 04:03 PM
baneonrt baneonrt is offline
I would think there is nearly a 100% chance that it'll be a saddle pack. It's a sticking point with me also but I'd rather deal with that and have the parts support this will bring with it than settling on another buggy based on the battery configuration. I was about to pull the trigger on a ZX-5 when I read the press release.
Steve
Old 07-11-2007, 04:13 PM
juntom10's Avatar
juntom10 juntom10 is offline
ummmm based on bj4...and change some parts..umm
i want truggy!!!!!!!!!!!
Old 07-11-2007, 08:57 PM
isawred isawred is offline
sweet mary and joesph.... i want one !!!! any sort of release time frame??
Old 07-11-2007, 09:01 PM
Originally Posted by isawred View Post
sweet mary and joesph.... i want one !!!! any sort of relase time frame??
Sept 2007 is what the release said on another forum. Which means sometime in the Nov-Jan area.
Steve
Baby jesus willing, it will be soon.
Old 07-11-2007, 11:00 PM
winter time ought to be just right to venture into 4wd buggy!!! i know it's brutal out there right now and those things tend to run hotter....
Old 07-11-2007, 11:07 PM
Linkster's Avatar
Linkster Linkster is offline
Wow!!!!! Hmm... RC8 or B44 such a hard decision... I know Ill get both.
Old 07-12-2007, 01:28 AM
t9dragon t9dragon is offline
I would like to see some naked pics.................
Old 07-12-2007, 05:20 AM
Kden46 Kden46 is offline
Man I can't believe I lived long enough to see Associated Come out with a 4wd buggy!!!! hehehehe
And yes where are the body off pics?
So could this be the 4wd Electric Buggy to breathe new life into the class?
Old 07-12-2007, 07:39 AM
masterchief06's Avatar
masterchief06 masterchief06 is offline
Well this is what everyone's been waiting for! Shoot, with how awesome it looks, I might just jump on the bandwagon...
....Given the right pricetag
Old 07-12-2007, 11:20 AM
Where are the body off pics?
Old 07-12-2007, 11:55 AM
redbarton redbarton is offline
I hope this is successful enough that they come out with a non-factory team kit or RTR for us po' folks. An affordable electric 4x4 truggy, which could handle brushless power, would be even better!
Old 07-12-2007, 07:16 PM
Tamiya4ever Tamiya4ever is offline
Yeah I was thinking the same thing. This and the TC5.
Old 07-12-2007, 09:24 PM
nitro_newbie's Avatar
nitro_newbie nitro_newbie is offline
wow this looks awsome i wonder how durable it will be compared to the bj4? how durable is the bj4 any how.
1 14 cell widemaxx
1 12 cell narrow maxx
1 BL/nitro savy with .21bb and axial .28
BL rc18mt: make over in the works
