Is it the old tup chassis GT? If so, get a transmission and engine mount brace by Trinity, or get the new chassis by Associated. If not, stop landing off of a jump with the throttle on. When your car is in air, the wheels spin faster because there is no weight the engine has to pull. When you land, there is a LOT of stress on the gears because of a car that wasn't there, appeared. Land the jump with less throttle if its the new chassis and you'll be fine.
Marriage is the only war where you sleep with the enemy.
You must always push the limits. Because if you never fail, you will never succeed.
0 Cuss out the turn marshals because they cussed at you!!!
Crashing is an art of driving that goes bad in result in human or mechanical error.
